Community
cancel
Showing results for
Search instead for
Did you mean:
RReag
Re: NUC Kit 5i5RYK -driver updates
I have almost the same problem with my NUC Kit NUC5i5RYK.
When I run https://www.intel.com/content/www/us/en/support/intel-driver-support-assistant.htm it shows there are 2 updates:
Although I ran the updates several times en rebooted , the new drivers will not install. I do not get any faults when the installers are running. Version 12.15.25.6 is never removed. I'm really stuck here.
st4
New Contributor III
Hi Ronnie98,
Thank you for the post. I will move your inquiry to our NUC support for them to better assist you. Thank you.
Sharon
Community Manager
Hello Ronnie98,
Thank you for bringing this matter to the Intel® NUC Community. I am sorry to hear you are having issues with these drivers.
What are the drivers versions installed in Device Manager?
Amy C.
RReag
Ethernet: 12.15.25.6712
Wireless: 19.51.7.2
Community Manager
/thread/119110 Ronnie98, thank you for that information.
I manually checked the driver version from https://downloadcenter.intel.com/product/83254/Intel-NUC-Kit-NUC5i5RYK Downloads for Intel® NUC Kit NUC5i5RYK, and you do have installed the latest versions for these components. I must be an conflict with the tool showing other versions.
Amy C.
RReag
Amy,
Thank you for your reply. I however do not get it.
My installed ethernet driver version is 12.15.25.6712
I do not see this version on the download page.
On the download page the latest driver is version 22.7.1
Community Manager
Sure /thread/119110 Ronnie98, and I can explain that. So, the 22.17 version you see is actually the package version, once you install the package it displays the version itself. I installed myself in one of our units and I see 12.15.25.6712 as the version installed.
Amy C.
RReag
OK, so my drivers are up to date. The Intel Driver Assistant is wrong however.
Tnx for investigating...
Ronnie
Community Manager
Sure Ronnie, you{re welcome.
If you have more questions, please let us know.
Amy C.
FF3
Sorry to bump in, but I have the same issue on a NUC5PGYH, with wireless driver and Intel trusted execution engine driver. No matter now many time I re-installed, including removal and re-install, repair, update, all options, those two keep coming in as not updated. So you say it's ok and it is an Intel Driver Assistant issue?
Community Manager
Check for the latest updates for your Intel® NUC model in https://downloadcenter.intel.com/ Drivers & Software, the tool might show inconsistencies with some drivers.
If you need further assistance, please create a new thread.
Amy C.
