Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Ready Mode requires password on exit
I have a kiosk system I setup and due to the NUC's inability to come out of sleep from my remotes I'm trying ready mode. Problem is even if I disable password on startup, password to resume from sleep or hibernation, when coming out of ready mode it requires me to login again. How do I stop this?
Steve
Highlighted
Community Manager
Steve5623: Thank you very much for joining the Intel® NUC communities. We are sorry to hear the NUC is not working as expected.
In order to better assist you and to look for possible troubleshoot steps to try:
What is the specific model of the NUC?
What is the model of the remotes?
Which Windows version are you using?
Any further questions, please let me know.
Alberto R
Highlighted
see my other thread here for everything about my system
Steve
Highlighted
Community Manager
Steve5623: Thank you very much for sharing that information.
In regard to your inquiry, there must be a different setting to enable the automatic login when coming out of Intel® Ready Mode. Since the configuration we are looking for is at Windows level, the best thing to do will be to get in contact with Microsoft directly in order to confirm if there is a workaround to avoid this scenario:
https://answers.microsoft.com/en-us https://answers.microsoft.com/en-us
Alberto R
Highlighted
You folks need to step up your support. Be happy you have a job and take it seriously. All responses here are not good.
Here's the facts:
1. Microsoft has settings to allow auto-login when booting up a system. Settings in Windows (Windows 10 in this case)
2. Microsoft has settings to allow resume from hibernate and skip logging in. Setting in Windows.
3. Microsoft has settings to allow resume from sleep and skip logging in. Setting in Windows.
4. And this is the important one. Intel, if you are familiar with the technology, came out with what's called Ready Mode. It's an Intel only technology, used in Intel only equipment, and isn't something that most people have or use. It's software you install and built, that support hardware you build. You folks need to be able to add in the ability to skip login when coming out of YOUR Ready Mode.
Steve
Highlighted
Community Manager
Steve5623: Thank you very much for providing that information. We apologize for any inconvenience. At this point, we will do further research on this subject, as soon as I get any updates I will post all the details on this thread.
Alberto R
Highlighted
Hi Steve Y,
Intel® Ready Mode Technology is only supported on desktop and All-in-One PCs. Please see the following website for further information: https://www.intel.com/content/www/us/en/support/technologies/000020651.html
On the other hand, I will be looking into the following thread https://communities.intel.com/thread/118048 https://communities.intel.com/thread/118048 and I will get back to you.
Ronny G
Highlighted
Thanks for looking into my other thread Ronny. Appreciate it.
Steve
Highlighted
Does this mean that it is not compatible with NUC's?
Highlighted
Super User Retired Employee
The BN NUCs *are* Desktop PCs. Intel Ready Mode Technology is most definitely supported.
Highlighted
I already guessed it, but then, I do not find much sense in Ronny's response...
Highlighted
I was totally wrong and thanks for pointing that out, my apologies for that, see this link: https://downloadcenter.intel.com/download/26483/NUCs-Intel-Ready-Mode-Technology-for-NUC-Kit-NUC7i3B...
Let me do some more research and I will get back to you.
I will also try to fix the incorrect web site about Ready Mode being only supported on AIO.
My apologies again for the incorrect reference.
Ronny G
Highlighted
Hi Steve5623:
Please help me out to better understand the issue.
You have the operating system password disabled so that when the system boots up it goes directly into Windows and there is also no password for the system to resume from Sleep or Hibernation but when coming out of Ready Mode Technology (RMT) it requires that you login back again with the password you disabled for Windows? Is this correct?
I don't see any further option to set up anything related to it on RMT.
Highlighted
Ready Mode appears to have been killed in the BN NUC. I do not see any option in the BIOS to enable it anymore.
