Intel® NUCs
12130 Discussions
Recently purchased an NUC8i5BEK for use in a conference room. I'd like to connect it to two 50" televisions for dual monitor display. Any advice/recommendation on the best way to connect the two displays? Thanks in advance for the response.
SBelb
n_scott_pearson
Super User Retired Employee
You want two independent displays? Connect one to the HDMI connector. Connect the other to the USB-C connector with a USB-C-to-HDMI adapter like this one: https://www.amazon.com/Adapter-uni-Thunderbolt-Compatible-MacBook/dp/B075V68NVR.
Hope this helps,
P.S. I am not endorsing this adapter; I use it purely as an example.
