Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Reinstall Windows 10 - NUC6CAYS
I installed Linux on my NUC out of the box. After no end of issues trying to get the configuration right, I want to revert to a Windows 10.
I have downloaded Windows 10 Home 64 bit. When I start the install it asks me for the drivers.
I have downloaded the drivers and placed them on USB and the installation SD card. They are not detected and I cannot proceed.
Any advise on how to get Windows 10 installed on the NUC again?
Highlighted
I understand that you have erased Windows 10, preinstalled on the e-MMC card. In order to install Windows 10 on your NUC, no additional drivers are required on your installation USB. You need to prepare your installation media correctly (my advise is to use Microsoft Media Creation tool):https://www.microsoft.com/en-us/software-download/windows10 Download Windows 10 . Doing so, you will have the latest version of Windows downloaded to your USB media. Your USB will be bootable too.
Install Windows according to the following tutorial: https://www.tenforums.com/tutorials/1950-clean-install-windows-10-a.html Windows 10 Forums . Skip on para 12 and install Windows with UEFI bios as described in para. 13. In step 13.B, take care to choose the right partition for Windows installation.
Once your installation is completed, install Intel drivers downloaded here: https://downloadcenter.intel.com/product/95078/Intel-NUC-Kit-NUC6CAYS Downloads for Intel® NUC Kit NUC6CAYS . Instead of downloading each driver separately you can download Driver Bundle zip and unzip it on your drive. Install all driver manually (do not use Intel Driver Update Utility). Start from installing Chipset driver and reboot your NUC. Install all the other drivers. You can reboot your computers once only, after all drivers are installed.
Hope this helps.
Leon
