Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13517 Discussions
Remote port, card reader HUB solution
Les_Noble
I have a NUC10i7FNH as a boat computer and want to put it behind a panel and hide wires etc. Looking for a solution to have peripheral connections on the panel plus card readers. A usb hub would work, but desire the MIC to annoy the world with youtube vids.
Minimum: SD, MicroSD. USB3(2), USBC, MIC.
A bay mounted media hub (or panel mount) would work best, but they are set up for desktop cases that have spare connectors.
I am not using the thunderbolt port, so that is available to run a hub from. Plug something into the header?
The MIC jack could be standalone, just longer wire.
Power: could run 12v from batteries to not tax NUC power supply. Powered USB would be desirable as alternate charging ports.
I also have a 19v dc-dc power supply that has remote power switch leads. The 2mm connectors are too tall to fit in case. Are there shorter or 90 degree versions?
I am a computer user and rarely get under the hood and not sure what options are open.
Thanks for any input.
Greg
AlHill
You might want to look here for lids that have the I/O you want:
https://www.gorite.com/intel-nuc-products/intel-nuc-replaceable-lids/10th-gen-nuc-lids
[Windows 11 is the new Vista]
Les_Noble
Didn't know about lids, thanks.  However as a kiosk scenario, I wont have access to ports or lid.
Closest example is this, but NUC doesn't have 19 pin connector, I think.
https://www.amazon.com/BYEASY-Inches-Internal-Reader-Type-C/dp/B08DKDHMGR/ref=sr_1_1?keywords=Front+Bay+hub+card+reader&qid=1639278731&s=electronics&sr=1-1
I did buy a panel mount MIC jack with wire connections to extend that piece. If the 19 pin USB cable can be swapped for a USB cable to the thunderbolt port, this is winner. This technical question if over my head.
Even though there are no spare power connections, that can be dealt with.
I am also running Linux Mint on NUC and this says its compatible.
