Intel® NUCs
Support for Intel® NUC products
12755 Discussions
Removing the system board - what is the trick?
KenTaylor
I have a small, entry level Pentium processor NUC. Recently I updated the BIOS which fixed a couple of issues and of course caused another issue. That may be the subject for another post. At the moment I am wanting to try my universal fix all technique - disconnect everything from the system and pop the CMOS coin battery.
Intel's documentation shows that the battery is on the processor (top) side of the system board. I have opened the case, removed the only two screws I can find which secure the board. While the board will move around a bit it certainly will not lift out.  I trust someone in the community knows the trick.
TIA,
Ken
LeonWaksman
Hi @KenTaylor
Although this tutorial shows how to remove board in NUC8i7BEH, however, the idea is the same.
Hope this will help you.
Leon
AlHill
Why do you not provide the NUC model number?
KenTaylor
Thanks Doc,
Because there are a whole bunch of NUCs the same size nominal 2" tall case. I would not expect the system boards to be installed differently.  If it helps here is the # BOXNUC7PJYH1.
Ken
LeonWaksman
Hi @KenTaylor
Leon
KenTaylor
Thanks Leon, an excellent reference. I guess I need to disconnect a couple more things and PRY. That said...
My upgrade to the ....0057 version of the BIOS fixed my surging power fan and unstable video. However, I found that I could no longer boot the NUC from my Clonezilla USB drive. This is a key component in my workflow. I install a version of Linux, update, configure, then take a snapshot of the OS to an external drive using Clonezilla. When I am done with that project  I may try a different Linux distro for some other experiment etc. I have a collection of ready to go Linux images which I can restore to the internal SSD on the NUC in just a few minutes. Provided of course I can boot the Clonezilla live image.
Clonezilla is based on an Ubuntu or Debian Linux operating system. I have tried both. Neither would boot the NUC. The NUC would boot from a base Ubuntu image on a USB drive.  Very strange.  I then updated the BIOS to ....0058 whchh came out just a few weeks after ...0057. Now the NUC will not boot at all. I have warranty support ticket open with Intel.  I suspect it may have to go back and THEY can pry the pieces apart if needed
Again thanks for the tutorial link. I will keep it handy once I get the NUC running again.
Ken
