The mail below was from a "do not reply" address, so this is the best I can do as far as answering:
Re:Port protocol capabilities.
Kupuna, Thank you for posting in the Intel® Communities Support.
In order for us to answer your questions in the most accurate way, first, we just wanted to confirm a few details about your system:
What is the model of the video tablet?: Huion Kamvas 13 Model GS1331 Manufactured in 2020
Is this a new Intel® NUC? It is a NUC817HVK (Oct.2019 I believe)..
Were you able to successfully do this procedure before with this specific Intel® NUC? Yes with a 3-headed cable (HDMI, power, image) takes 3 ports.
Which Windows* version are you using? V. 21H2 19044-1645
Are you planning to use this configuration at home or in the work environment? Home Environment.
Albert R.
