Would it be possible to run your NUC on a external battery like this one if you do not have normal power supply?
https://www.amazon.co.uk/gp/aw/d/B013HXKZYW/ref=ox_sc_saved_image_1?smid=A28QVT3E6UV0FU&psc=1 Poweradd Pilot Pro2 23000mAh Multi-Voltage (9V 12V 16V 19V 20V) Portable Charger External Battery Backup Power Bank with…
Thankful for help/reg B.
Hello Brad999
Thank you for posting in the Intel® community.
Allow me to share with you that we have not tested or validated the External Battery Backup but it should work as long as the adapter or one of the laptop adapters match the NUC.
Please let us know how it goes if you decide to go through the purchase.
Hope this helps.
Leonardo C.
Under Contract to Intel Corporation
Hi, thank you for response.
The cables (adaptor) are no priblem, but maybe it needs some kind of extra adaptor between 19v/4.5A battery and NUC or if its plugged directly to the NUC....
Anybody with electrical experience that can sort this out?
Maybe some kind of battery regulator or stabilising device?
Would the battery data be sufficient for the NUC?
Reg. / Brad
