Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Run skull canyon at 24V?
Hey out there,
does anyone has informations about if its possible running the skull canyon safely over time with an 24V power supply instead of the original 19V?
JamesT
Tags (1)
Highlighted
Community Manager
Hello JamesTSkull,
Thank you for joining the Intel® NUC community.
The Intel® NUC can be powered through a 19 V DC, using a DC with a higher voltage may not perform as expected and can damage the motherboard. We recommend complying with this requirement in order to ensure the lifespan of the motherboard and its components. From my end we have only tested the Intel® NUC under its specifications.
The electrical and power supply considerations can be found on the following link: https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC6i7KYK_TechProdSpec.pdf https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC6i7KYK_TechProdSpec.pdf
Amy C.
Highlighted
Community Manager
/thread/117687 JamesTSkull,
If you have more questions, please let us know.
Amy C.
