I am Using intel NUC717bnb
I try to install the SGX from the intel website it says i am using windows 10 Enterprise but i am using windows 10 pro .
i have also clean install windows 10 and all driver are updated
need your help
Thank you
- Did you downloaded this driver? https://downloadcenter.intel.com/download/27118/NUCs-Intel-Software-Guard-Extensions-Intel-SGX-for-I...
- Did enabled SGX security in BIOS? You need to configure Intel® SGX as “Enabled” in BIOS before you install SGX .
Leon
The install was Successful of the SGX software
Hi
I did enabled SGX in the bios before install.
I will try to download the drive you gave the link .
Thank you
having the same problem, not sure if windows 10 1809 is the issue or not but powerdvd 18 is telling me SGX is not enabled in the bios or not supported by this platform
Ya that is what i am also trying to do run my 4k uhd Bluray
Try to downloaded this driver? https://downloadcenter.intel.com/download/27118/NUCs-Intel-Software-Guard-Extensions-Intel-SGX-for-I...
The software will install but the 4K UHD will not work.
so little info i have found, but either Microsoft screwed up, Intel has, or powerdvd needs updating to reflect a change by one of the first two, i get the same results from the compatibility checker as yourself
this is what you requested.
Adding bios SGX option setting let me know if its ok
Still not working for me
For me the cyber link uhd advisor tells me SGX is disabled and if I try and play a film through powerdvd 18 it asks me to install the SGX sdk I believe which fails saying not supported on this system
intel nuc7i7bnk I’ll try and run the tool but wasted time I didn’t have already on this, only change since last using is upgrade to bios version 71 and windows 10 1809 which is kinda forced on you
i noticed bios 72 was released with a mention about a SGX fix but still couldn’t work it out
Hi the software is installed successfully but PowerDVD18 is not recognizing the SGX and i cannot play my 4k Blu-ray disc .
So i don't know if there is a problem with the intel side or powerDVD18 side .
If you need any info about the issue please let me know .
thank you
Ya i did contact Cyberlink on the same day as i contacted you
hi they respond and gave me some steps to try to fix the issue like reinstall the program , run the compatibility test ,update windows , update bios but nothing worked
All this step where done on fresh copy of windows 10 pro 1809.
HI please check which Bios Ver are you on .
Ver 0072 works fine for me .
https://downloadcenter.intel.com/download/28475/BIOS-Update-BNKBL357-86A-?product=95065
Hi the installation was successful but the SGX was still not detected by Powerdvd .
