Is this drive supported in the high chassis and the nuc 10 and 11 where it fits?
Do they supply enough power?
Hello @xayide
Thank you for posting on the Intel® communities. Please allow us to check this inquiry further and we will be posting back as soon as more details are available or if additional information is required.
Note: If your inquiry is regarding more specific Intel® NUC 10th and 11th generation models, please feel free to provide details.
Andrew G.
Hello xayide
Thank you for your patience in this matter.
Regarding this request, since no specific Intel® NUC model was provided about this inquiry (only referred to Intel® NUC 10th/11th generations in general), what we recommend is to review the Intel® Product Compatibility Tool so you may check the components and peripherals that have been tested with a specific NUC, including the supported drive models. For instance, here are some Compatibility lists for the following models:
- Intel® NUC 10 Performance kit - NUC10i7FNK
- Intel® NUC 10 Performance kit - NUC10i3FNH
- Intel® NUC 11 Pro Kit NUC11TNKi7
Based on the Intel NUC capabilities, it may show subsections for Drives M.2 PCIe, SSD, HDDs, etc. The focus of the testing is to make sure that there are no obvious issues between the Intel NUC and devices and software. Samples of publicly available peripherals are used to see if the Intel NUC achieves a high level of compatibility. For more details, please review Tested Peripherals for Intel® NUC Products.
If looking for enough power and size, we recommend checking the Technical Product Specifications for Intel® NUC Products, but this is general information.
Andrew G.
Hello xayide
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
