Intel® NUCs
Support for Intel® NUC products
12726 Discussions
SSD in base of NUC 11
billyjo2002
I have recently bought a barebones NUC 11 Kit (RNUC11BTMI70000) and provided a 500Gb OS SSD and a 1TB storage SSD. Everything is working fine except, I note that the 1TB drive cannot be seen when mounted in the slot in the base of the PC but is fine if mounted in one of the internal slots. Both SSD's are Crucial P5 Plus CTxxxxP5PSSD8 (PCIe 4.0, 3D NAND, NVMe, M.2 Gaming SSD) up to 6600MB/s.
Is there any good reason the drive can't be seen in the bottom slot or do I have a faulty machine?
Jean_Intel
Hello billyjo2002,
To have a better understanding of your issue, please provide me with the following:
  • Is the issue present since day one?
  • If you try to use another drive in the slot you have issues with, the problem persists?
  • Check if the BIOS detects the drive:
    • Press F2 during boot to enter BIOS Setup.
    • Go to Advanced > Devices > SATA (or Advanced > Storage.)
    • See if the drive is detected and identified on the SATA Port or the M.2 Port.
    • Press F10 to exit BIOS.
Jean O.
Jean_Intel
Hello billyjo2002,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello billyjo2002,
Jean O.
billyjo2002
Apologies for the late reply - your responses went into Junk.
  • Is the issue present since day one? YES
  • If you try to use another drive in the slot you have issues with, the problem persists? NO SSD CAN BE READ IN THE LOWER SLOT
  • Check if the BIOS detects the drive: NO SSD DRIVE IS DETECTED IN THE LOWER SLOT AND DOES NOT APPEAR IN THE BIOS LISTING
The SSU report ss attached
Thanks, Ivor
