Intel® NUCs
SSD partition
albertliaw
My Intel NUC 5i5RYH comes with 128GB M.2 SATA.
I partitioned into two.
Now I wish to combine back into a single partition.
Please advise how.
AlHill
Microsoft question.   However, (assuming the 2nd partition follows the 1st) delete the second partition, and then extend the first partition.
albertliaw
Unfortunately, the 2nd partition does not follows the 1st partition. There is another partition in between.
AlHill
Then, you have a problem.   Contact Microsoft for help on resolving this.  This is not an Intel problem.
albertliaw
The partition in between is called Recovery Partition, it is only 526MB (see attached png file).
What is this partition for, can it be deleted?
AlHill
You are not listening.   We do not provide support for Microsoft problems, so stop asking.
Ask Microsoft for support on their OS.  That way, if you screw it up, or Microsoft screws it up, it is between you and them.
albertliaw
Thanks, I thought it is Intel system "Recovery Partition".
Now I know it is Microsoft problem.
Bye.
