I have an Intel Nuc (BOXNUC8i7BEH1) with a 2TB SSHD running Ubuntu 16.04.6 LTS. The Nuc itself was faulty, so I removed the RAM and SSHD and got a replacement from the vendor.
When I put the SSHD and RAM into the new box, it doesn't boot. Partitions are thus:
sda 1.8T
├─sda4 swap 977M [SWAP]
├─sda2 vfat 3.3G PQSERVICE
├─sda3 ext4 1.8T /
└─sda1 vfat 47.7M /boot/efi 'EFI System
Instead of booting, I get the "Ubuntu Recovery" screen where my only choice is to do a restore.
I am -pretty- sure I've swapped SSHDs between Nucs (we've got multiples of the same model).
What am I missing? Thanks.
Your NUC only supports Windows 10.
https://www.intel.com/content/www/us/en/support/articles/000005628/intel-nuc.html
You can try updating the BIOS, or contact linux.org for assistance.
Doc
I don't think that's true, since I'm currently running Ubuntu on 19 other of the same box.
I said SUPPORTED, not that linux would not run. Read the document I linked to.
And, the NUC is booting. It is just your linux setup that is corrupted..
Or, install Windows, or reinstall linux.
Doc
ok, thank you.
