Provided Drivers for LAN adapter is not accepted by Windows PE Boot image
I have added the Drivers posted in NUC 12 drivers to the boot image. But I still get this error:
A connection to the deployment share ... could not be made.
The following networking device did not have a driver installed.
PCD\VEN=8086&DEV_15F3&SUBSYS_30248086&REV_03
Hello MarcW,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® NUC 12 Pro Kit NUC12WSKi7.
1. What is the exact Windows version and build that you are trying to install?
2. What is the BIOS version installed?
3. Do you have any internet/connection issues due to this error?
4. Did you check with Microsoft to confirm the proper steps and drivers?
Deivid A.
Hello MarcW,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
Hello MarcW,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Regard,
Deivid A.
I tried to respond by mail, but I found out it was a no-reply mail.
What I am trying to do is to Deploy NUC by using Microsoft Deployment Tools (MDT) via PXE network boot..
It works fine until the LAN driver is needed in the Windows PE, PXE boot image. I have tried to add the drivers that you provide on your web site to the boot image via MDT console, but it seems that the drivers will not load in the Boot Image. I have done before with NUC v6 without problems. Microsoft Says that the issue is with the network driver provided by you, that it will not load in the Windows Preinstallation Environment. The windows version that I try to install is Windows 11 (Latest version just downloaded from Microsoft.
Did you get this sorted out??? I am having the same problems and cannot figure it out...
Thanks!!
