Hi
Actually I have NUC7 i5 BNH
If I buy the monitor in the subject, will I be able to use the resolution 3840x1080?
If my model is not compatible, can you report other NUC models that are compatible?
thanks
KADKAM, Thank you for posting in the Intel® Communities Support.
In reference to your question, the Intel® NUC Kit NUC7i5BNH works with the Intel® Core™ i5-7260U Processor, that processor has
Intel® Iris® Plus Graphics 640 as the graphics controller and depending on the video port that you will use, the Intel® NUC Kit NUC7i5BNH has HDMI 2.0a; USB-C (DP1.2), yes, it does support the 3840x1080 as you can confirm in the link below:
There are a lot of Intel® NUCs that are capable to support the 3840x1080 resolution, in order to see the specifications of them, please visit our official site, select the Intel® NUCs as product in order to confirm those details:
https://ark.intel.com/content/www/us/en/ark.html
We always recommend also to use a straight connection, like for example an HDMI to HDMI cable, without using adapters or converters that might limit the capabilities of the graphics controller. So, if the monitor supports that resolution you should be able to work with it with no problems, for that please get in contact directly with the manufacturer of the monitor to confirm that information.
Albert R.
Albert R.
Hello KADKAM, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
