Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
12003 Discussions
Screen blanking randomly when using DisplayPort NUC8I7HVK4 + ASUS VZ27AQ monitor
FMcKi
NUC8I7HVK4 with ASUS VZ27AQ monitor.
Bios: 2.2.25
Windows 10 Pro 64bit
Connected via DisplayPort
AMD Driver version: 24.20.11021.1000
Any game I play I see the monitor blank for a few seconds.
Seems to happen randomly. Doesn;t seem related to load as fans are not necessarily going hard when it happens.
Happens in older game: Divinity: Original Sin Enhanced.
Ashes of Singularity - Escalation.
Step taken to troubleshoot:
Set Scaling Mode to Full Panel
Disabled IGP in Bios
Playing with HDMI doesn't show the same problem. But no freesync as my monitor requires DisplayPort for that to work.
Rest Bios to factory defaults
CHecked sensors during Ashes of Singularity.
Load onCPUs was around 20%
GPU was at around 51 degrees C
Uninstalled drivers for both display adapters so display adapters only showing: Microsoft Basic Display Adapter
Installed Intel Graphics driver
Restarted pc
Install Amd diriver.
Restarted pc.
Still happening.
What next?
Foigal
Community Manager
Hello Foigal,
Thank you for contacting our community forums.
In this case, we are performing further investigation regarding the issue that you are experiencing.
In the meantime, please provide me with the .txt file that the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- System Support Utility will generate. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
I hope to hear from you soon.
Diego S.
FMcKi
Hi Diego,
Here is the SSU output.
Fergus
Community Manager
Hello Foigal,
Thank you for your response.
Based on your report, there are certain updates that we would like you to perform.
Your current BIOS is .0037 while the latest version is .0049
Please update your BIOS gradually, you can jump to .0040:
https://downloadcenter.intel.com/download/27808/BIOS-Update-HNKBLi70-86A- https://downloadcenter.intel.com/download/27808/BIOS-Update-HNKBLi70-86A-
And then to .0044:
https://downloadcenter.intel.com/download/27889/BIOS-Update-HNKBLi70-86A- https://downloadcenter.intel.com/download/27889/BIOS-Update-HNKBLi70-86A-
Finally to .0049 (latest):
https://downloadcenter.intel.com/download/28073/BIOS-Update-HNKBLi70-86A- https://downloadcenter.intel.com/download/28073/BIOS-Update-HNKBLi70-86A-
In order to update it, you can follow any of these methods:
https://www.intel.com/content/www/us/en/support/articles/000005636/mini-pcs.html https://www.intel.com/content/www/us/en/support/articles/000005636/mini-pcs.html
As well, In order to isolate the issue we will need you to uninstall the current graphic drivers that your system has (both Intel® and Radeon*), until the basic Microsoft*display driver is exposed (please make sure that you will do it with no internet access)
After that, for troubleshooting purposes please install the latest Intel® HD Graphics Driver for Windows® 10:
https://downloadcenter.intel.com/download/28079/Intel-HD-Graphics-Driver-for-Windows-10-64-bit-for-t... https://downloadcenter.intel.com/download/28079/Intel-HD-Graphics-Driver-for-Windows-10-64-bit-for-t...
In order to do it, please go ahead and perform this update steps:
Unzip the file to a designated location or folder.
Open Device Manager:
For Windows 10: Right-click Windows Start icon
Click yes when prompted for permission from User Account Control.
Expand the Display adapters section.
Right-click the Intel® graphics entry and select Update Driver Software.
Click Browse my computer for driver software.
Click Let me pick from a list of device drivers on my computer.
Click Have Disk.
Click Browse and select the directory where the driver files are located.
Click OK, and finally click Next.
Drivers are now being installed.
Restart your computer.
Once that is done, please follow the same steps to update your Radeon™ RX Vega M Graphics Driver for Windows® 10:
https://downloadcenter.intel.com/download/28080/Radeon-RX-Vega-M-Graphics-Driver-for-Windows-10-64-b...
I hope to hear from you soon, please let us know the outcome.
Diego S.
FMcKi
Did the 3 progressive Bios updates.
Unplugged LAN
Uninstalled both display drivers so Microsoft Basic Display Adapter showing in Device Manager.
Installed the Intel Driver downloaded from your link.
Restarted pc
Installed Radeon driver
Restarted pc
Rand SSU
Attached report
Have tested in Ashes of Singularity and no screen blanks.
I will continue playing and update in a few days or if I see more screen blanking.
FMcKi
Still happening I am afraid.
Next suggestion?
Foigal
Community Manager
Any of the games in the list here cause the problem if so let me know and will have a look have TV connected VIA Display Port to HDMI as was looking t see if I could get rid of the flickering in Videos using EDGE or there Apps but no luck on that yet but do have a 4K HDR 60hz TV turning up in 2 weeks to replace my 1080 59hz only TV As I think it may be the problem All Videos run fine in Chrome so that is my work around for now
So if you have any in this list let me know and I will see what happens
Community Manager
Hello Foigal
There is a new update in our Intel® HD Graphics Driver for Windows® 10 that includes new fixes.
Please uninstall you current Intel® HD Graphics Driver for Windows® 10 as shared before until the basic Microsoft*display adapter is exposed again, and then download the latest version:
https://downloadcenter.intel.com/download/27988/Intel-Graphics-Driver-for-Windows-10?product=126790 https://downloadcenter.intel.com/download/27988/Intel-Graphics-Driver-for-Windows-10?product=126790
I hope this helps, please let me know the outcome.
Diego S.
FMcKi
Hi Alan,
I don't think you are dealing with the same issue.
But thanks for the input.
Foigal
Community Manager
Do we really need this driver if the Intel GPU is disabled in the Bios kind of seems pointless to install drivers for a GPU that is not even running
FMcKi
The driver update appears to have solved the problem. I have had 5-10 hours of play without seeing the problem pop up!
So thanks!
Fergus
