Community
cancel
Showing results for
Search instead for
Did you mean:
SBar
Screen going black or flickering
It comes and goes. sometime for days there is no problem and it suddenly returns. a few days ago I downloaded a windows update "creative fall" or something and it made things much worse. I rolled back the windows version and re-installed everything that is to be installed by inter (drivers, support programs and such). so far to no avail. It is so bad that I can't use my one year old computer anymore.
These are the technical details from the intel system support util:
# SSU Scan Information
Scan Info:
Version:"2.5.0.12"
Date:"12/17/2017"
Time:"00:00:26.0281862"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Intel Corporation"
BIOS Mode:"UEFI"
BIOS Version/Date:"Intel Corporation RYBDWi35.86A.0354.2016.0120.0912 , 01/20/2016 12:00 AM"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"Intel(R) Core(TM) i7-5557U CPU @ 3.10GHz , GenuineIntel"
Secure Boot State:"Not Available"
SMBIOS Version:"2.8"
Sound Card:"High Definition Audio Device"
System Manufacturer:"Not Available"
System Model:"Not Available"
System SKU:"Not Available"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"1.7.47.0"
- "Intel(R) Iris(TM) Graphics 6100"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1.00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Iris(TM) Graphics 6100"
Link:" http://www.intel.com/content/www/us/en/search.html?keyword=Iris+Graphics+6100"
CoInstallers:"igfxCoIn_v4835.dll, CoDeviceInstall"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmd64.sys"
Driver Date:"10/16/2017 03:00 AM"
Driver Path:"C:\WINDOWS\system32\DRIVERS\igdkmd64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"20.19.15.4835"
INF:"oem91.inf"
INF Section:"iBDWM_w10"
Install Date:"Not Available"
Installed Drivers:"igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll,igdumdim32,igd10iumd32,igd10iumd32,igd12umd32"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_162B&SUBSYS_20578086&REV_09\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"60 Hz"
Refresh Rate - Maximum:"75 Hz"
Refresh Rate - Minimum:"59 Hz"
Resolution:"1920 X 1200"
Scan Mode:"Noninterlaced"
Service Name:"igfx"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) Iris(TM) Graphics Family"
- "Memory"
Physical Memory (Available):"4.51 GB"
Physical Memory (Installed):"8 GB"
Physical Memory (Total):"7.89 GB"
- "CHANNEL A DIMM0"
Capacity:"8 GB"
Channel:"SODIMM0"
Configured Clock Speed:"1600 MHz"
Configured Voltage:"0 millivolts"
Data Width:"64 bits"
Form Factor:"SODIMM"
Interleave Position:"Not Available"
Manufacturer:"1315"
Maximum Voltage:"Not Available"
Memory Type:"DDR3"
Minimum Voltage:"Not Available"
Part Number:"CT102464BF160B.M16"
Serial Number:"00000000"
Status:"Not Available"
Type:"Synchronous"
- "Motherboard"
BIOS:"BIOS Date: 01/20/16 09:12:17 Ver: 05.0000B, INTEL - 162"
Caption:"Motherboard"
Chipset:"Not Available"
Date:"01/20/2016 02:00 AM"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"NUC5i7RYB"
Serial Number:"GERY54200BKD"
Status:"OK"
Version:"H73774-102"
- "Networking"
I...
LeonWaksman
Please update your bios with the latest version: https://downloadcenter.intel.com/download/27230/BIOS-Update-RYBDWi35-86A-?product=87570 Download BIOS Update [RYBDWi35.86A]
You have very old version(0354). The bios was updated since this version 11 times. The latest version is version 0367
I'll suggest you to update your bios using bios recovery: https://www.intel.com/content/www/us/en/support/articles/000005532/mini-pcs.html BIOS Recovery Update Instructions for Intel® NUC . Download bios file: Ry0367.bio and save is on fully formatted USB. Format your USB to FAT32 (do not use quick format, use full format).
Try to recover your BIOS from Power Button Menu. In order to boot into Power Button Menu, you should release the Power Button soon as the power led changes color from blue to amber. NUC will reboot into Power Button Menu. With the USB containing the latest bios file, press F4 and the recovery shall start.
Leon
