Intel® NUCs
Assistance in Intel® NUC products
13298 Discussions
Self signed cert in chain from only some servers
Caitlin
I have multiple Intel NUCs out in the field that I use for displaying digital signage. Out of the thousands I have in the field, a couple complain with this error:
SSL certificate problem: self signed certificate in certificate chain. More details here: http://curl.haxx.se/docs/sslcerts.html, curl performs SSL certificate verification by default, using a "bundle" of Certificate Authority (CA) public keys (CA certs). If the default bundle file isn't adequate, you can specify an alternate file using the --cacert option. If this HTTPS server uses a certificate signed by a CA represented in the bundle, the certificate verification probably failed due to a problem with the certificate (it might be expired, or the name might not match the domain name in the URL). If you'd like to turn off curl's verification of the certificate, use the -k (or --insecure) option.
I've confirmed that the cert is not expired, and the domain name matches
These units are running on Debian 7
Could the network they are on cause this issue with some sort of firewall setting?
IntelSupport
Community Manager
Hello Caitlin,
Thank you for posting your question on this Intel® Community.
To better assist you, please provide us with the following system report.
Intel® System Support Utility for the Linux* Operating System
https://downloadcenter.intel.com/download/26735/Intel-System-Support-Utility-for-the-Linux-Operating-System
How many units are being impacted by this issue?
Wanner G.
IntelSupport
Community Manager
Hello Caitlin,
If you need further assistance, please let us know. We will be glad to assist you.
Wanner G.
IntelSupport
Community Manager
Hello Caitlin,
We have not heard back from you, so we will close this inquiry. If you need any further assistance with other issues or inquiries, please post a new question. We will be glad to help you.
Wanner G.
