I have an Intel NUC10i3FNKN with Win 10 Home.
Device Manager is showing "No compatible drivers for Base System Device"
I tried to run SetupChipset but got an "Unknown Error" message. Log files attached
Help!
According to the log file, you were installing version 10.1.1.8. This version is much too old to be used with this NUC. For all 7th-13th gen NUCs, you are supposed to be using version 10.1.19284.8351, which you can download from here: https://www.intel.com/content/www/us/en/download/19695.
Hope this helps,
P.S. I suggest that you install the package using command ".\SetupChipset.exe /overall". This will ensure that all associated chipset device are updated.
Hope this helps,
