Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Sharing folders in computer to computer scenarios (No router)
Hi
we're on win10 enterprise IoT.
The NUC is essentially a "BlackBox" to the end user.
It would be sweet to share a folder from the unit as a network-drive.
For the particular use we have in mind, a direct connection (computer-to-computer) would be preferable.
I can do that on my mac's (:) ), but haven't made that happen with the NUC yet...
Do I need a twisted-pair cable, or does it just "not work".
If it works, a pointer would be great.
Gunleik
Highlighted
Super User Retired Employee
Here's an experiment to run. Connect the two PCs with a standard LAN cable. Go to the first PC (the "server") and set it to have a static IPV4 IP address of 192.168.0.1. Set the subnet mask to 255.255.255.0. Create a folder share while you are at it. Reboot the PC. Now, go to the other PC (the "client") and set it to have a static IP address of 192.168.0.2. Set the subnet mask to 255.255.255.0. Set the DNS server IP address to be 192.168.0.1. Reboot the PC. Once rebooted, try to ping 192.168.0.1. If you can, then you are good to go. If you cannot, however, you may need a crossover cable/dongle.
Hope this helps,
Highlighted
Great, thanks
I'll try this.
G
