Community
cancel
Showing results for
Search instead for
Did you mean:
Skull Canyon NUC is not able to turn on monitor after it is turned off due to inactivity Windows 10 x64
Jump to solution
I am using a DELL S2718HN/NX monitor connected on HDMI port, but I had similar issues with another brand as well.
If I select in Power Options (Windows 10) the computer to go to Sleep in say 10 minutes when idle, everything works fine. It goes to sleep and when I press a key it turns back on just fine.
However, I do not want the NUC to go to sleep, just to turn off the monitor (because I use it as media server and I need it on). So I change the configuration to Sleep: Never, Turn display off: 10 minutes.
Now the problem issues: Display is turning off, but when I press a key it does NOT turn on. Everything else is working, but the display is off. I can connect to the NUC with TeamViewer and see the desktop.
From TeamViewer I can put the NUC to sleep and then, when I press a key the monitor turns on fine. Sleep works ok, but display off does not.
What I have noticed by looking into the Device Manager (with team viewer) while the display was off, is that at the moment I press a key to wake up the monitor, the monitor driver switches from PnP Generic Monitor to Non-PnP Generic Monitor, and the monitor remains off.
As stated above, if from this state I put it to Sleep and then press a key, it turns back to PnP Generic and monitor turns on. I have also tried DELL's monitor driver as well but it behaves the same.
Any ideea anyone?
Accepted Solutions
Community Manager
AlexCD: Thank you very much for contacting the Intel® NUC communities. We are sorry to hear the NUC is not working properly.
In order to try to fix this problem, we can try to install driver 4849:
https://downloadcenter.intel.com/download/26259/NUCs-Intel-HD-Graphics-Driver-for-Windows-10-for-Int... https://downloadcenter.intel.com/download/26259/NUCs-Intel-HD-Graphics-Driver-for-Windows-10-for-Int...
Just to confirm if this scenario might be related to a regression bug, if the problem remains with the driver above, please install the following which is version 4821:
https://downloadcenter.intel.com/download/27227/Intel-Graphics-Driver-for-Windows-15-45-?product=883... https://downloadcenter.intel.com/download/27227/Intel-Graphics-Driver-for-Windows-15-45-?product=883...
Did you make any recent software/hardware changes on the NUC, like a Windows update?
In reference to this problem, did the NUC work fine before?
Did you get in contact with Microsoft about this scenario in order to get further suggestions?
https://support.microsoft.com/en-us/contactus/ https://support.microsoft.com/en-us/contactus/
Any further questions, please let me know.
Alberto R
Community Manager
Alberto R
Thank you very much, updating the driver did solved the issue.
Community Manager
AlexCD: Perfect, thank you very much for letting us know that information. We are glad to hear the problem got fixed and now the NUC is working properly.
Alberto R
