Hi there, I've a skull canyion nuc6i7kyk but one of the smd component bust in the motherboard. I can't locate boardview or schematic anywhere, ¿please could someone give me a hand?
Next you can see two photos, one of the good component and another with the bust component. Thanks in advance.
avico, Thank you for posting in the Intel® Communities Support.
In reference to " I can't locate boardview or schematic anywhere,", in the following link you will find the mechanical drawings of the Intel® NUC Kit NUC6i7KYK, please look for the "Intel® NUC Kit Drawings" tab, once you get the chance, please let us know if that information was useful for you:
https://www.intel.com/content/www/us/en/support/articles/000006820/intel-nuc.html
Albert R.
No, the OP won't find anything pertinent there.
The development team is telling me that the fried part is a PL528 inductor.
Hope this helps,
Thank you very much.
Sorry,
Thank you for the info.
The ferrite bead is connected directly to the power jack (19V). Is this normal? Or maybe some other component caused that voltage thus causing the burst?
So did you run this hot or did it blow on a normal setting? Just wondering, because I'm starting to worry that high-end NUCs run too hot!
Here's a response from the development team:
Yes, it’s normal that it’s connected directly to the 19V input. It’s part of an input filter for the RT6220 voltage regulator also mentioned in this thread. Replacing the ferrite bead may or may not fix the issue. The ferrite bead could have blown because something else downstream died or shorted and the ferrite bead was the weakest link in the chain so to speak. Assuming the unit is out of warranty at this point, I’d say it’s worth a shot if you feel competent to do the soldering rework. It can’t make it any worse.
Hope this helps,
Wow I wouldn't expect such an "embedded" support from Intel or any other brand. Thank you so much. I bought 5 RT6220, and I managed to solder one of them, but same result. I will try again as soon as I get more precise equipment.
Thank you!
I was a part of this team before I retired, so I know where they live (literally). ;^)
Let me know how it goes...
