Community
cancel
Showing results for
Search instead for
Did you mean:
HGrah
Standby Power Limits
What is the maximum current (power) which can be drawn from the NUC7i5/NUC7i7 5VSTBY power rail (CEC Header) when
  1. the NUC is shutdown (FAN off)
  2. the NUC is powered up (Fan active)
Harry
Community Manager
Hello laquebrada,
Thank you for joining the Intel® NUC Community. I will do my best in order to help with this matter.
Please let me double check this, I will update the thread as soon as possible.
Amy C.
Community Manager
/thread/121727 laquebrada,
Can you please verify the Intel® NUC models that you are interested in?
Amy C.
HGrah
Amy,
NUC models of interest are NUC7i5BNH and NUC7i7BNH.
laquebrada
Community Manager
Thank you for the clarification.
Amy C.
Ronny_G_Intel
Hello /thread/121727 laquebrada,
While on standby the bus gives 5V to the CEC Header and you are asking what the CEC power consumption is when the system is in power off (S5) state, am I correct? I would assume that you are implementing some sort of wake up via CEC by using some power in deep sleep stages. Can you please provide some more details about it?
Ronny G
HGrah
Hello Ronny,
To be clear as possible, I am asking what 5V over CEC header power consumption is possible when the system in is power off (S5) state. We are implementing logic which must be powered at all times, even when the system is in S5 state. This logic does not wake the system.
laquebrada
Ronny_G_Intel
The maximum is 1A in shutdown or operating stages, this limit is due to the physical size of the pin used in the 1x4 CEC header.
I hope this helps.
Ronny G
