Intel® NUCs
Assistance in Intel® NUC products
Startet
Silvio49
Mein Intel Nuc Starte nicht richtig ,ob wohl ich alle nach Beschreibung gemacht habe. Und wenn ich Ihn Starte Blinkt das Blau Licht nur, als das Es Konstanz Brennt, an was kann das liegen??? Oder was mache ich FALSCH??????????
n_scott_pearson
Super User Retired Employee
If you are seeing a pattern of three flashes when you press the Power Button LED, it is an indication of either bad memory or (more likely) memory that is incompatible. This page provides some basic troubleshooting steps: Intel® NUC Won't Start, Power LED Blinks/Beeps Three Times During POST.
Hope this helps,
DeividA_Intel
Hello Silvio49,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® NUC 10 Performance kit - NUC10i3FNH.
1. Based on the response from n_scott_pearson, what is the blink code that you are getting?
2. Have you tested with a different RAM or SSD?
3. Is this issue present out of the box?
4. Do you see any physical damage inside the NUC?
Deivid A.
DeividA_Intel
Hello Silvio49,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello Silvio49,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
