Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11989 Discussions
Support for WDS120G2G0B coming?
JHuve
WDS120G1G0B is supported. But replaced by WDS120G2G0B.
The WDS120G1G0B is not reconginsed in the NUC. Tested it with anonther device, there it works.
Also see https://forums.intel.com/s/question/0D70P0000068VecSAE (here the G2 is replaced by a G1 and then it works.
I'm using the NUC5i3RYH with the latest BIOS update.
LeonWaksman
Please clarify your question. If I understand correctly, you have WDS120G2G0B SSD which is not recognised in BIOS? The same SSD works in other computer?
Leon
JHuve
Yes. It works on other computers. The NUC does not recognize it. I Found: https://forums.intel.com/s/question/0D50P0000490S7HSAU/nuc7i3bnh-doesnt-recognize-wd-green-120gb-m2-... which also show a G2 not being recognized. Although the user states it was a broken SSD that got replaced, the working replacement in the screenshots is a G1.
The 1 is on the compatibility list from Intel. The 2 unfortunately not.
LeonWaksman
Looks that you are right. I see also that although the G2 is the newer model, the G1 has better performance.
Leon
