Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13513 Discussions
Switch from Legacy boot to UEFI Boot
AZguy
I have an Intel Nuc8i7beh that is set to legacy boot. How do I switch it to use UEFI?
SSD: Samsung 970 EVO Nvme using a Guide Partition Table
AlHill
Fairly easy to do.
First, make sure you have a backup of your data.
Then, open the bios to determine where the setting is to change to uefi boot. Do not change it, yet.
Then, boot your system and use MBR2GPT. Here is a link, for your convenience, on how to do this:
https://www.tenforums.com/tutorials/81502-convert-windows-10-legacy-bios-uefi-without-data-loss.html
As soon as the conversion is done, reboot to the bios and make the switch from legacy to UEFI boot.
Then, reboot your system.
Doc
AZguy
Thank you Al.Hill
What if your disk is already using a Guide Partition Table?
AlHill
Is it a bootable disc, or just a disk you formatted as gpt?
Doc
AZguy
It currently boots up under legacy mode. So yes the disk is bootable.
AlHill
go to start, and scroll all the down to Windows Administrative Tools and select Computer management. Then, select disk management. Take a photo of the graphic showing the disk in question.
Provide that photo.
Doc
AZguy
AlHill
ok, download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
