Community
cancel
Showing results for
Search instead for
Did you mean:
HSokv
Tamper-evident for NUCs - with timestamp
Hello.
I am looking for a way to upgrade NUCs we use for an appliance with some timestamp-supplying tamper-evident technology. Is there maybe some easy way to do it with an intel NUC? It's simply for opening the case.
Community Manager
Hello sokhan83
Thank you for reaching the Intel(R) Communities.
Would you please further elaborate on this request?
  • What would be the reason why you want this?
  • What is this solution for
  • Which are the models of the Intel(R) NUCs used?
This is to clarify your inquiry and proceed accordingly with support.
Esteban C
AlHill
I checked a few NUCs and did not find any with intrusion detection. I have seen and used this feature on desktop boards before.
It is typically used to protect corporate assets, which could be theft of internal devices or bios configuration changes. It is a good feature, which usually involves the use of a switch, which is opened (or closed) upon opening the case.
Doc
n_scott_pearson
Super User Retired Employee
While the PCH used in the SOC-based NUCs retains Intrusion Detection latch support, the INTRUDER# signal is not brought out to a header that would allow a chassis-open switch to be connected. This, unfortunately, means that a solution that is not dependent upon the PCH is necessary...
Community Manager
Hello sokhan83
This is to do a follow up to your case and find out if you have further questions.
Esteban C
