The fan control on my new NUC8i5BEH is not working. The fan is running permanently on 4000 rpm even if CPU cores are idle on temp 30 celsius
I have already tried the "Cooling" settings in BIOS from @n.scott.pearson as written in https://community.intel.com/t5/Intel-NUCs/NUC8i7BEH-high-fan-noise/td-p/644343.
Even the setting for "Fixed" did not change the fan speed.
Running the Prime95 put my CPU on 70 celsius, but the fan speed did not change.
Accordingly Intel Driver and Support Assistant I have newest drivers and BIOS version (v. 83)
Is my new NUC fan control broken? The fan running on 4000 rpm is very noisy.
Any advice?
Adrik
I'd check the physical connection also to see if it's plugged in correctly, if the sense wire has a broken connection it could also affect the fans like this.
Hi @Adrik
1. Similar problem was reported in this thread. Could be you got one of this faulty NUC? Just joking. Any way, I suggest you that you open ticket to replace your NUC (even better to replace it in the store you have bought it).
2. Is your NUC a new one and this problem exists from first use, or it happened later. If this problem started after some time of use, what event proceeded the failure?
Leon
Hi @LeonWaksman
thank you for the thread link, it looks like I have the same problem as written there.
Yesterday I have recovered BIOS with v83 with no success.
It looks like my unit and the unit from @fan-man were produced on same day
I will return my unit and go for the new one or try NUC8i5BEK2 as an alternative.
Adrik
forget to mention, that I have a new unit bought 3 days ago and the problem exists from first use. My unit was produced on 06/2020 and came with BIOS v83 already installed
Adrik
Hi Adrik,
Are you aware that NUC8i5BEK2 is the "low" NUC (i.e. there is no place for 2.5" SATA drive and you have only M.2 slot on the board). So, why you are not trying other NUC8i5BEH ?
Leon
Hi @LeonWaksman
thanks for the info. I ordered the new NUC8i5BEH now, try another supplier.
Adrik
today I have received the new unit NUC8i5BEH, but it has the same problem. Fan permanently on ~ 3700 rpm.
Both units are produced on 06/2020.
Somebody with new ideas?
Adrik
Same here.
Bought a NUC8i5BEK on amazon (europe).
Date of Manufacture: 03JUN2020
Fan constantly running at 3830 rpm!
It doesn't matter what fan profile I use, always the same result.
Really sad, this is my 1st NUC, I'll send it back....
Adrik, Thank you for posting in the Intel® Communities Support.
I just wanted to check if the problem with the Intel® NUC fan still persists and if you need further assistance on this matter?
crix, Thank you for posting in the Intel® Communities Support.
If the problem persists after replacing the Intel® NUC, please submit your inquiry on a new thread, the reason for this is that every scenario is different even if the same product is being used, so for us to better assist you and in order to try to fix the problem, please submit a new thread:
https://communities.intel.com/community/tech
Let me apologize for any inconvenience.
Albert R.
A Contingent Worker at Intel
Hello Adrik, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
Hi Alberto,
unfortunately, both units of NUC I have purchased in Europe were broken (produced 06/2020), I have sent them back. It looks for me that the quality assurance for NUC production at Intel does not exist.
This was my first experience witch NUC and probably my last.
Adrik
P.S The case could be closed
