Intel® NUCs
Assistance in Intel® NUC products
13298 Discussions
The max network speed in thunderbolt 4 net?
Jia_lao
Can I get real  40Gbps network speed ?
If I link directly by thunderbolt4 port with two NUCs , just file share or ip communication, don't use other device like display , USB, etc...
Alberto_R_Intel
Jia_lao, Thank you for posting in the Intel® Communities Support.
In reference to your question, according to the link below, you should be able to reach 40Gbps of network speed when using Intel® Thunderbolt 3 or 4:
https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/thunderbolt-overview-brief.pdf
You will find further details about Intel® Thunderbolt here as well:
https://www.thunderbolttechnology.net/tech/faq
Still, we will do further research on this subject to confirm that information. As soon as I get any updates I will post tall the details on this thread.
Albert R.
Alberto_R_Intel
Jia_lao, I just received an update on this matter.
After checking the case we can confirm that yes, the Intel® NUC should be able to reach 40Gbps network speed if the adapter being used supports that speed.
Here you have the link for the Intel® Compatibility Tool where you might find different cables that support that speed, tested and validated by Intel®:
https://compatibleproducts.intel.com/
Albert R.
