My question might be basic as I don't have much idea about computers. Which of the following monitors would be compatible with the NUC indicated above:?
(1) LG 22 inch (55cm) IPS Monitor - Full HD, IPS Panel with VGA, HDMI, DVI, Audio Out Ports - 22MP68VQ
https://www.amazon.in/dp/B01IBM5V66/?coliid=I2WJNV5VGFH3AH&colid=3LH2GXHS79XXH&psc=1&ref_=lv_ov_lig_dp_it
(2) HP 21.5-inch (54.6 cm) Edge to Edge LED Backlit Computer Monitor - Full HD, IPS Panel with VGA, HDMI Ports - T3M71AA
https://www.amazon.in/gp/product/B01F8LCALM/ref=ask_ql_qh_dp_hza
(3) Dell 21.5-inch (54.6 cm) LED Backlit Computer Monitor - Full HD, TN Panel with VGA, HDMI Ports - 091T856
https://www.amazon.in/dp/B07436JM87/?coliid=IP5S2T4R8FCCP&colid=3LH2GXHS79XXH&psc=1&ref_=lv_ov_lig_dp_it
(4) Samsung 23.5 inch (59.8 cm) Curved LED Backlit Computer Monitor - Full HD, VA Panel with VGA, HDMI, Audio Ports - LC24F390FHWXXL
https://www.amazon.in/dp/B01GFPGHSM/?coliid=I3Q2PKCTI2MVPV&colid=3LH2GXHS79XXH&psc=1&ref_=lv_ov_lig_dp_it
Thanks for your time.
All of them "should" be. You can find tested monitors here:
http://compatibleproducts.intel.com/ProductDetails?EPMID=95067
Doc
The fact that a monitor/TV is not in the compatible products list does not mean it will not work. It just means that it has not been tested for compatibility (sample units were not supplied to Intel for this testing).
All of these are lower resolution monitors (i.e., only require HD support, not UHD (4K), QHD, etc.) and should work fine. Use good cable, not the crap that comes with the monitor/TV.
