Hello
Does anyone know the thermal pads thickness for the Intel NUC7I7BNH?
I’m under the impression that 1mm is way to thick.
TheDigitalJockey, Thank you for posting in the Intel® Communities Support.
In order to provide the most accurate response to your inquiry, we will do further research on this matter, in order for us to be able to do that, we just wanted to confirm a few details:
Is there any reason in particular why you need this information?
Are you a developer?
Are you working on a project?
Alberto R.
A Contingent Worker at Intel
Hello TheDigitalJockey, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Alberto R.
I apologize for the delay.
I'm not a developer. I'm trying to stop the throttling and when I've removed the cooling system, I've noticed that the pads are not in good shape.
By the way, where can I purchase an WI-FI antena for the NUC? Mine broke loose when removing the board.
- You may purchase the replaceable WiFi antennas on Amazon. Some examples: https://www.amazon.com/Pair-NGFF-Antenna-Antennas-Intel/dp/B01FK6IHEY/ref=sr_1_7?keywords=wifi+anten...
https://www.amazon.com/IPEX-Internal-Antenna-M-2-Wireless/dp/B07QDTXGGJ/ref=sr_1_3?keywords=wifi+ant...
https://www.amazon.com/HUYUN-Antenna-Cable-Module-Internal/dp/B07DB6ZG3B/ref=sr_1_2?keywords=wifi+an...
2. You may stop the CPU throttling by adjusting the Cooling settings in Bios. Set: Fan Control Mode to Custom, Primary Temperature Sensor to Processor,
Fan Off Capability - uncheck/disabled, Minimum Temperature to 80, Minimum Duty Cycle to 30, Duty Cycle Increment to 4,
Secondary Temperature Sensor to Memory, Minimum Temperature to 60, Minimum Duty Cycle to 30, Duty Cycle Increment to 4.
3. Press F10 confirmed by "Y" to save settings and exit from bios.
Leon
Hello TheDigitalJockey, No problem at all, thank you very much for providing that information.
We will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Alberto R.
Hi Everyone,
I have been looking internally for any documentation that reports out the thickness of the thermal pad but I couldn't find anything, It seems that this information was not made available in the product documentation that we can share with our customers.
If you are having any issue with our product please do not hesitate and contact us back.
Ronny G
