Intel® NUCs
12312 Discussions
This device cannot start. (Code10) 1219-V
Frustrated
Hi I just bought an Intel NUC 10 Performance Kit NUC10i5FNH.
I have loaded Windows 10 on it and done the windows updates.
The Ethernet port does not work. The cabling is correct and I have the error message This device cannot start. (Code10) 1219-V. There is a steady light on the NUC port but no corresponding ethernet port on the switch port it is connected to.
In device manager there is a yellow warning triangle next to "Intel(R) Ethernet Connection (10) 1219-V and when I click on it I get the error message. This device cannot start. (Code 10). (Operation Failed) The requested operation was unsuccessful. I tried hitting the pdate button and advised I had the latested driver version.
I have also updated the NUC bios but the Ethernet port still does not work.
How can I fix this?
Alberto_Sykes
Frustrated, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
When did you purchase the Intel® NUC?
Was it working fine before?
When did the issue start?
Did you make any recent hardware/software changes?
Which Windows* version are you using?
For testing purposes, by any chance, do you have the option to connect the Intel® NUC to another switch?
In this case, what we can try is basically a clean installation of the latest Ethernet (LAN) driver, so please go to device manager and select "Uninstall", then try to install version 24.5:
https://downloadcenter.intel.com/download/29951/Intel-Ethernet-LAN-Network-Connection-Driver-for-Win...
You mentioned "I have also updated the NUC bios but the Ethernet port still does not work", even if the latest BIOS version is already installed, please try to install again the version 0046, this time using the BIOS recovery method, in the link below you will find two options to do it, using the "power button" or the "recovery jumper", we suggest to try the one with the power button first:
https://www.intel.com/content/www/us/en/support/articles/000033291/intel-nuc.html
https://downloadcenter.intel.com/download/29924/BIOS-Update-FNCML357-?product=189239
If the problem persists after trying the steps above, please provide the SSU report so we can verify further details about your platform:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91...
Albert R.
A Contingent Worker at Intel
Alberto_Sykes
Hello Frustrated, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Alberto_Sykes
Frustrated, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
Frustrated
Sorry your responses ended up in my Spam folder.
In answer to your questions....
Q) When did you purchase the Intel® NUC?
A) About 3 weeks ago.
Q) Was it working fine before?
A) It would not connect to Ethernet from new
Q) When did the issue start?
A) Straight out of the box
Q) Did you make any recent hardware/software changes?
A) No
Q) Which Windows* version are you using?
A) Windows 10 home
Q) For testing purposes, by any chance, do you have the option to connect the Intel® NUC to another switch?
A) Other devices connecting to the same switch work fine and I have plugged the NUC into a port used successfully by another device.
Frustrated
I tried the above. I first uninstalled the Device which appeared to work successfully. I then used the driver update I downloaded from the above link. ...buyt when I veiw the Driver in Device Manager it reports a driver version of 12.19.13 and a date of 26/08/2020?
Frustrated
"You mentioned "I have also updated the NUC bios but the Ethernet port still does not work", even if the latest BIOS version is already installed, please try to install again the version 0046, this time using the BIOS recovery method, in the link below you will find two options to do it, using the "power button" or the "recovery jumper", we suggest to try the one with the power button first:
https://www.intel.com/content/www/us/en/support/articles/000033291/intel-nuc.html"
Sorry I have no idea which Bios Update to download from the links on that page.
Frustrated
OK I managed to work out which one to use and I have updated the bios but still no change in my fault status or original error description.
Frustrated
SSU file attached
Alberto_Sykes
Frustrated, No problem at all, thank you very much for providing that information.
We will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
Alberto_Sykes
Hello Frustrated, I just received an update on this matter.
After reviewing the case and based on the fact, as you mentioned, that the cables are working fine and so are other devices connected to the same switch, that the light on the switch where the Intel® NUC is connected does not turn on and after trying all those troubleshooting steps, we determined that there might be a hardware problem with the Ethernet port itself on the Intel® NUC and we suggest then to replace the unit.
You can try to do this with the place of purchase directly or you can always get in contact with Intel® Support for them to further assist you with the replacement process:
Chat support:
http://intelsupportchat.force.com/icslivechat/ics_tech_processor_ww_english_Chat,
For phone support, depending on your location, you will see the contact information on the links below:
EMEA contact information: https://www.intel.com/content/www/us/en/support/contact-support/emea-contact.html
APAC contact information: https://www.intel.com/content/www/us/en/support/contact-support/apac-contact.html
LAR contact information: https://www.intel.la/content/www/xl/es/support/contact-support/lar-contact.html
North America: Phone Number 1-916-377-7000, Monday – Friday 7:00 AM to 5:00 PM (Pacific Time).
Albert R.
