Intel® NUCs
Support for Intel® NUC products
12330 Discussions
Thunderbolt issues on NUC11PABi5 front panel is fine, but the rear one is not woring.
Justin666
Hi Guys, my new NUC 11 has a wired problem with the thunderbolt port . When I use the thunderbolt port of the front panel can light up my monitor with usb-c calbe (AOC u2790pc that has a type-c port), but with no signal if use the thunderbolt port of the rear panel.  when type-c cable is connected to the display via both TBT ports , the USB hub of the moniotor can work normally. I have reset the BIOS by clearing the jumpers on the motherboard and reinstalling all the drivers like as the Graphic ,TBT , chipest even as the monitor's , and i changed a new cable with 40gbs full speed but the problem isn't solved.
i sent the inside messege via intel support one week ago , but no any  reply.
Any body can help me?
Windows 10 21H1
Device management capture attached
David_G_Intel
Hello Justin666
Thank you for posting on the Intel️® communities. We understand you have opened a support web ticket with us and we will continue to help you through that channel now. We will therefore close this community case. Thank you.
David G
