Hi everyone I'm new to the forum, thank you for having me. I have a NUC11PAHi5 currently running two Asus PB278 monitors at 2560 x 1440. My issue is monitor 1 is clean looking and smooth. Monitor 2 is pixelated and fuzzy. I swapped the cables maybe it was bad display. Then monitor 1 was pixelated. I bought new cables, same issue.
Monitor 1 is Mini-DisplayPort to DisplayPort supports up to 4k at 60Hz
Monitor 2 is USBC to DisplayPort - I tried using HDMI to HDMI on this monitor same issue.
Bios is latest version and graphics drivers are up to date. I'm at a complete loss as why this is happening. Any thoughts?
Hello McDx,
To have a better understanding of your issue, please provide me with the following:
- When did the issue start?
- Was there a hardware or software update before the issue started?
- Have you tried using another set of monitors?
- Does the issue persist when you configure the monitors differently?
- You mentioned that you are not using straight connections; could you try to connect the monitors using straight cables?
- Create a report using the Intel
System Support Utility (Intel SSU) - Download the Intel SSU (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-window...)
- Open the application and click on "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click on "Next"; then "Save."
Jean O.
Hello McDx,
I hope you are doing fine.
Jean O.
Thank you for getting back to me Jean
I was able to somewhat figure the issue out. The fist monitor is an Asus PB278 and the second monitor is a PB278QV. I just so happen to have an extra PB278 at work so I brought it home and now the two PB278's are working perfectly connected to the intel NUC.
As for the PB278QV. I plugged it in at work and even though its a 1440p display, the highest option i see is 1920x1080. I posted a screenshot. It just refuses to go higher than 1080p on any computer with any cable.
I came to the conclusion that this PB278QV is broken.
Thank you again for the help.
Hello McDx,
I am glad to know you found a solution to your issue and concluded that the PB278QV monitor is the root of the problem. I will keep this case open just in case you face your issue again using this set of monitors.
Let me know if you still need assistance.
Jean O.
Hello McDx,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
