After updating to the latest BIOS yesterday, version KCTGL357.0043.2022.1021.2047, my USB-C dock monitors are no longer working and give a error: "Display Connection might be Limited". I tried to downgrade to both the 0042 and 0040 versions, but neither helped. This is the only update that was done between the monitors working and not working. The USB devices connected to the dock are functioning, but not the HDMI monitors. I tested the dock in another laptop with a compatible port, and it work perfectly.
Is this a known issue or are there other configuration parameters that need to be changed to get this back working?
Jdenotter, Thank you for posting in the Intel® Communities Support.
In reference to your question, yes, there might be parameters/settings that need to be changed in order to try to fix this problem.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the complete model of your Intel® NUC?
When did you purchase it?
What is the model of the monitors?
Are you using adapters or converters to connect the monitors to the USB-C dock?
Which Windows* version are you using?
Albert R.
Here are the answers to your questions:
What is the complete model of your Intel® NUC? System Model: LAPKC71F
When did you purchase it? Approximately 6 months ago
What is the model of the monitors? I have 2 HP 24F monitors
Are you using adapters or converters to connect the monitors to the USB-C dock? They are connected directly into the dock by HDMI.
Which Windows* version are you using? Operating System: Microsoft Windows 11 Home(10.0.22621 Build 22621)
Does the problem happen at home or in the work environment? Home
I submitted a support ticket through the SupportTickets portal under ticket number 05696138.
Hello Jdenotter, Thank you very much for sharing that information.
Perfect, please keep checking your ticket number 05696138 since we will provide all the updates and a possible solution on this matter in there.
Albert R.
