I have owned and used a USB Microphone for around a month now. However, on Saturday, I went to use it and it stopped working.
The microphone is still recognised by my laptop (and is set as default output when connected), but when I go to the test audio setting nothing is getting picked up. On audacity and the default audio recorder on my laptop, error messages are displayed when I try to record.
I have tried:
- Connecting my microphone to another device - microphone and lead work perfectly
- Using all the USB ports my laptop has (including using a different lead and USB-C connector) - problem still occurs
- Connecting other devices to the USB port (e.g. USB mouse) - these work
- My laptop internal microphone also works, it's just this external one
Once I established it likely wasn't a hardware issue, I tried a number of software steps:
- Sound troubleshooter - no problems were picked up
- Checked permissions for the microphone in settings
- Updated drivers and BIOS
- Ran SFC and DISM - no problems
- Uninstalled microphone using device manager (then re-installed)
- Ran troubleshooting on USB ports - no problems
None of these fixed the issue! Do you had any advice on what I can try?
audioissues, Thank you for posting in the Intel® Communities Support.
In reference to this case, just to let you know, pretty much you tried all the troubleshooting steps that we recommend for this kind of scenario. Still, with that in mind, in order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the model of the laptop?
What is the model of the USB Microphone?
Is this a new computer?
When did you purchase it?
Was the USB microphone working fine before on this specific machine?
This problem, only happens when using "Audacity" or does it happens all the time you tried to use the USB microphone?
When did the issue start?
Did you make any recent hardware/software changes that might cause this issue?
Which Windows* version are you using?
Albert R.
Hello audioissues, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Hello audioissues, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
