Intel® NUCs
12115 Discussions
USB Type C Power Delivery Controller Install Issues
IBarg1
I've been unable to update the USB Type C Power Deliver Controller Driver with latest version. Unfortunately, the install is failing. I went to check on the device via device manager and found the device to be in STATUS_DEVICE_POWER_FAILURE with its status reporting a Code 10. I've tried uninstalling the device and deleting its driver followed by a shutdown and power up. Unfortunately, the problem persists.
The below is what is being reported in the General Tab
TI USB Type-C/Power Delivery Controller
Device type: System devices
Manufacturer: Texas Instruments
Location: on Intel(R) Serial IO I2C Host Controller - A160
Device status
This device cannot start. (Code 10)
Any idea what may be causing this problem? I suspect a conflict, but I'm not sure.
Equipment: NUC8i7HVK
n_scott_pearson
Super User Retired Employee
I had this issue with my HV as well. Updating to BIOS 37 and installing all of the latest drivers fixed this issue. Do yourself a favor: forget IDSA for a while and manually download and install all of the latest BIOS, software and driver packages available in the HV download page (here: https://downloadcenter.intel.com/product/126143/Intel-NUC-Kit-NUC8i7HVK Downloads for Intel® NUC Kit NUC8i7HVK).
Hope this helps,
n_scott_pearson
Hope this helps,
IBarg1
Scott,
Worked like a champ! Thanks a bunch!
