Recently i bought an Intel NUC8i5BEH (replacing a 6th generation NUC), only i noticed the USB ports don't work well when it has an USB hub connected.
I have connected powered and none-powered HUBs (5 different ones in total) to each of the USB ports, but i see 'randomly' disconnects of my serial devices. The devices ONLY work stable when i directly connect them, bypassing the HUB. There is nothing in any of my logs (normally I use Ubuntu 18.04/19.04).
It is this a hardware, software or design issue of the Intel NUC? I am happy to execute commands on the NUC if somebody wants more information . Because this makes me hesitant for future upgrades.
Hi Wanner,
Thanks for your fast reply.
I have tried the following 5 USB HUBs:
- SATECHI ALUMINUM 7-PORT USB 3.0 - ST-UHA37W / 879961003517 (https://satechi.net/products/satechi-7-port-usb-3-0-premium-aluminum-hub-for-imac-macbook-air-macboo...)
- Anker 4-Port Ultra Slim USB 3.0 Hub (https://www.anker.com/uk/products/variant/4port-ultraslim-usb-30-hub/A7516011)
- Sharkoon 4-Port USB 3.0 Aluminium Hub - 4044951016976 (https://sharkoon.com/product/1688/4PortU3AluHub)
- Ewent Flexible USB 2.0 HUB - 8716065277555 (https://www.ewent-online.com/ewent-ew1110-flexible-4-port-usb-hub.html)
- An Aliexpress USB 2.0 hub (https://nl.aliexpress.com/item/32773313266.html)
All of them give the same behavior, so it doesn't look like a faulty USB HUB. All last 4 HUBs worked perfectly on my previous Intel NUC6CAYH for more than 1 year.
I use my NUC for home automation, so I have connected the following devices:
- Aeon Stick S2 (https://www.amazon.co.uk/Aeon-Labs-USB-Z-Stick-S2/dp/B00E965Q9G)
- Aeon Stick Gen5 (https://aeotec.com/z-wave-usb-stick)
- RFXComTRX (http://www.rfxcom.com/epages/78165469.sf/sec820117c620/?ObjectPath=/Shops/78165469/Products/18103)
- P1 Meter (reads the power meter in Dutch houses - it is a serial to USB converter FTDI FT232R)
- Alarm (reads my alarm panel via a serial to USB converter, also a FTDI FT232R)
- An Arduino device for reading my water meter via USB port
- Zigbee2MQTT a CC2531 device for connecting to Zigbee devices
As I said earlier, this was rock stable on the previous NUC. When I connect them now to via an USB HUB I see disconnects/problems sometimes after 2hours, but maximum of 12hours that it happens. I have a few watchdog scripts running, who report the issues immediately.
Sorry, I can't test this on Windows, because then I can't use/test it with the devices connected to my USB HUBs (most don't have a Windows version for easy testing). I have ordered an USB 2.0 bracket, so I am curious if it is only the 4 USB 3.0 ports or also the USB 2.0. I will post also my findings when I have received it.
Hi Wanner,
Thanks for you reply.
Only it doesn't help me further with the problem, because I have tested with a powered hub and I don't believe any Intel validated hubs will 'solve' my problem. As i mentioned, the problem isn't shown directly and it depends on the equipment connected to it. I believe with a standard mouse/keyboard you won't see these type of issues. I am still happy to gather information, only I don't have Windows myself.
I also tried the latest version of my distribution (Ubuntu 19.04, so the latest kernel possible) with the same behavior.
I liked the old NUC6 and I thought (hoped) the new NUC8 would be worthy replaced. Only with these USB issues, I need to look for a different mini PC for my home automation.
Hello AKuip,
Thank you for your feedback. It is highly appreciated.
Although we are unable to replicate this behavior, we hope that other community members can provide further recommendations based on the devices you are connecting to your Intel® NUC.
Wanner G.
Under Contract to Intel Corporation
They are just horrible. Surface book 3 usb problems - check
Razer blade advanced 2020 usb problems - check.
Constant disconnects from keyboard and mouse. Constant.
Same with dells, Lenovos. All of them.
I am switching to AMD ASAP, and I suggest you do the same. Fix is not coming. This problem has been around for 2 years, and no one does anything about it.
