I’m not sure what to make of it being that the Intel i5-5300U has Intel HD-5500 Graphics which can output to 4k at 60HZ and is more than capable to output 1440P. I’m unsure if it some sort of driver issue or that’s just how these we’re supposed to be.
If you know anything about these older NUC’s and how they output signals please let me know what’s going on here!
- Thank you
I pulled the 4K@60Hz-capable mDP-to-HDMI adapter that I use with a later-generation NUC and plugged it into my MY NUC. I was able to make 4K@30Hz work, but I was never able to get 4K@60Hz to work. Unfortunately, while I have all sorts of 1080p and 2160p monitors, I have no native 1440p monitors that I could try, so I can't exactly repeat your test.
Question: What display driver package do you have installed? I am running the 15.40.48.5171 package (20.19.15.5126 driver), which is the last released that supported 5th gen processors.
try this one here https://www.intel.com/content/www/us/en/download/18369/intel-graphics-driver-for-windows-15-40.html
It's possible that the old driver got updated by WIndows Update. You could verify this in the event log of the gfx adapter. This can lead to an incorrect driver installation.
You could also try to remove the current video driver, and let WIndows UPdate push its driver to the device.
is this a passive adapter? HDMI with a passive DP to HDMI adapter strongly depends on the implemented Dual-Mode standard of the device. Older standards support up to 1200p@60Hz, newer standard is limited to 4k@30Hz. Current systems should be able to support HDMI2.0 resolutions via passive DP to HDMI cable/adapter.
This should not be an issue with active HDMI2 adapters, because DP port will provide DP signals.
