Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11991 Discussions
Unable to install Windows 10 on NUC7I7BNH from USB
DVill9
I was trying to install Windows 10 PRO, from an USB to my M.2 hard disk and I get an error during in the collecting information phase:
A media drive your computer needs is missing
Windows 10 ISO was downloaded from official site in Microsoft and burned to USB with Rufus program
I tried the following:
1. Changing to another USB port. Preferably from a USB 3.0 port to a 2.0 port or vice versa.
2. Install Intel Rapid Storage technology User Interface and Driver during the installation process:
https://downloadcenter.intel.com/down...
Screen Shots attached.
Please Help
n_scott_pearson
Super User Retired Employee
In order to support M.2 NVMe SSDs, you must use UEFI. When you create your media, you must choose to use the GPT file system. Similarly, when you install Windows, the SSD must be using the GPT file system. I usually delete all partitions on the drive (allowing Windows installer to overwrite with GPT partition table) and then tell Windows to install to the free space on the drive (which now encompasses the entire drive; this also lets Windows decide how to use the drive).
Hope this helps,
BHarr8
Valued Contributor I
Rufus is an unnecessary step if you are using the media creation tool. Have it create the bootable USB flash drive directly.
DVill9
I solved the issue burned Windows to a DVD
