Community
cancel
Showing results for
Search instead for
Did you mean:
KThak3
Unable to play 4k 10bit HVEC on NUC5i5MYHE, what am I doing wrong?
Hi
I am unable to play 4k files properly on a PC connected to a TV.
When I open a MKV file which is a 4K HEVC x265 I get no Video only audio. And when I forward the time, the audio plays fine, but the video shows a very choppy screen then the video is frozen and the audio continues.
I am not sure what the issue is.
Maybe I need to change settings, but I dont know what settings to change. (currently using default settings.)
Maybe my PC is not powerful enough to play this content at 4k? (but they advertise that they can do 2 screens at 4k just fine)
My Equipment:
Screen: LG OLED55B7V
Computer: NUC5i5MYHE (CPU: i5-5300U CPU @ 2.30GHz (4 CPUs) / RAM: 8GB / Using Intel SSD as content is stored locally / Intel HD Graphics 5500)
Media Player: VLC 2.2.6 Umbrella
My Files:
File 1
[quote]Format : Matroska
Format version : Version 4 / Version 2
File size : 39.3 GiB
Duration : 2 h 6 min
Overall bit rate : 44.3 Mb/s
Movie name : LoP
Encoded date : UTC 2017-01-31 21:31:45
Writing application : mkvmerge v9.3.1 ('Mask Machine') 64bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
FileExtension_Invalid : mkv mk3d mka mks
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 33.6 Mb/s
Width : 3 840 pixels
Height : 2 076 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 (23976/1000) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.176
Stream size : 29.8 GiB (76%)
Title : LoP
Writing library : x265 2.2+2-998d4520d1cf:[Windows][GCC 6.2.0][64 bit] 10bit
Encoding settings : cpuid=1050111 / frame-threads=3 / numa-pools=12 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2076 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=1 / no-allow-non-conformance / repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / bframes=3 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=40 / lookahead-slices=0 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=0 / no-limit-modes / me=2 / subme=7 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / no-deblock / no-sao / no-sao-non-deblock / rd=6 / no-early-skip / no-rskip / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=4.00 / psy-rdoq=8.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=22.0 / qcomp=0.80 / qpstep=1 / stats-write=0 / stats-read=0 / ipratio=1.10 / pbratio=1.00 / aq-mode=3 / aq-strength=1.00 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=51 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
[/quote]
File 2
File size : 14.2 GiB
Duration : 50 min 49 s
Overall bit rate : 40.0 Mb/s
Movie name : PE
Encoded date : UTC 2017-04-04 21:49:02
Writing application : mkvmerge v9.9.0 ('Pick Up') 64bit
Video
Format : HEVC
Format profile : Main 10@L5@High
Bit rate : 29.4 Mb/s
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.142
Stream size : 10.4 GiB (73%)
Title : PE
Writing library : x265 2.3+23-97435a0870be:[Windows][GCC 6.3.0][64 bit] 10bit
Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=12 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=1 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / bframes=3 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=40 / lookahead-slices=0 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=0 / no-limit-modes / me=2 / subme=7 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / no-deblock / no-sao / no-sao-non-deblock / rd=6 / no-early-skip / no-rskip / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=3.00 / psy-rdoq=6.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0...
n_scott_pearson
Super User Retired Employee
I am no expert when it comes to graphics technologies, but my understanding is that your platform only supports 8 Bit HVEC and you are passing in a 10 Bit HVEC file. This is likely why you have no video.
KThak3
KThak3
I have now tried this on a 6th Gen. And although the movie is playable, it is still very choppy.
DPurv
Another data point:
I've tried similar HEVC 4k videos on a NUC7i3BNH and
NUC7i5BNH, in both cases running Linux (opensuse).
They play correctly, but very slow frame rate (very choppy).
Intel support claims they run fine on Windows 10, even
on the i3 version.
TTX
7i7BNH -- 10Bit HEVC 4K 2160p (HDR) plays just fine on windows 10 fall creators update and Kodi with the latest intel drivers including hardware decoding.
