Screen flicker comes back to my NUC 7i5BN HDMI @4K 60Hz.
It was happened long time ago and was solved by graphic driver update. But Now screen flickers come back with new driver update, and will not go out even with I downgrade graphic driver.
Hope Intel can pay attention to this problem!
Thanks and Regards!
So, I think you are incorrectly using the description 'flicker'. You are seeing the monitor reset its image (and go blank for a second or so) on some regular basis, right?
The best answer I can give for this issue is for you to purchase a better quality dongle (if using USB-C connector) and/or better quality HDMI cable. And, before you say anything, it doesn't matter how well this cable (etc.) might work on some other PC, you need a better quality one for the NUC. More than 90% of similarly-reported issues are fixed with a better cable.
Aside: If you are going to use a 4K monitor with the BN NUCs, you should be using the USB-C connector and a USB-C to DisplayPort or USB-C to HDMI (one saying it supports 4K at 60Hz) dongle to connect to the monitor.
Hope this helps,
Hello 威王4,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Esteban Ch.
A Contingent Worker at Intel
