Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Unsupported signal. Check device output
New NUC7i7BNH system with 32Gb Optane Memory, 16Gb RAM, 1,5Tb HDD.
I am trying to connect system to Sony Bravia TV via HDMI cable/port.
For first week of using the system I had no problem connecting to TV.
Late last week, following either a Win10 update and/or Intel BIOS update, I have not been able to connect to TV. Now, after POST, I get a black screen with error display - 'Unsupported signal. Check device output.'
I am presuming it is a problem with BIOS as computer doesn't even get to point of loading operating system.
Do I need to roll back to previous BIOS or is their a new BIOS fix?
David Sanderson
Tags (3)
Highlighted
Community Manager
Hello DaveSanderson,
Thank you for contacting Intel® technical support. I will be more than happy to help you.
I understand that you are having issues with the system not booting up. In order to confirm if this issue is related to a BIOS upgrade or to a Windows® 10 update, you can try downgrading the BIOS version to at least to previous versions.
For instructions on how to perform a BIOS version downgrade, please follow the next link: https://www.intel.com/content/www/us/en/support/boards-and-kits/000006922.html
Xavier A.
Highlighted
Hi Xavier,
Thank you for your reply.
My question is not so much my NUC wont boot (it boots normally /fine to a monitor), it just wont boot when connected to the TV.
It used to boot to the TV, but since the updates (Windows 10 and/or Intel BIOS) it doesn't boot to the TV.
Do you think this still needs to roll back/downgrade the BIOS update.
Also, my system has ME loaded, so if I have to rollback/downgrade, I only have the BIOS Recovery Update method to use.
David
Highlighted
Community Manager
I was checking the ME Firmware versions of the latest and of previous BIOS versions. From the BIOS version 0047 (released on May 18, 2017) to the BIOS version 0052 (released on September 18, 2017), you will have the exact same ME Firmware version (11.6.27.3264).
You can check this and more information in the next link: https://downloadmirror.intel.com/27157/eng/BN_0052_ReleaseNotes.pdf
In short, it will be safe to downgrade the BIOS to any version down to 0047.
And, yes, I still recommend performing a BIOS downgrade to confirm if the latest update was the cause of the issue.
Xavier A.
Highlighted
I didn't get around to doing a rollback to the previous BIOS version, because shortly after getting your above email, I lost windows 10 - the whole operating system just disappeared along with all documents, etc..
So I figured I would do a fresh install.
After installing a fresh Windows 10, everything seemed to be fine. Everything was running - The Optane Memory, even working on the TV too.
Then, while watching some TV (the computer was still connected to the TV) today, Windows 10 performed another update... and you guessed it... the whole trouble started again, and MORE besides.
  1. I lost the HDMI - when I switched back to using the TV as a monitor to watch some recorded programs, I got the same Unsupported signal error. SO this seems to be a Windows 10 problem, not Intel. But wait, there's more....
  2. While typing (e.g. as I typed this response) the desktop would refresh/blink about every 10 seconds or so... When it does, I'd find that the insertion point had disappeared, so I had to select where I was typing again to be able to continue typing - this happened some 25 - 30 times; or
  3. After opening the Windows 10 Settings app, thinking to uninstall the most recent Windows 10 update, I find I cant access any options on the page (e.g. from 'Settings', 'Update & Security', then I find non of the options on that page wont open click one of the other options, but nothing happens, then, after about 10 seconds, the screen will refresh and the Settings window will instantly close, being unable to select any operation... this puts me in a dilemma,
  4. I cant use the Update & Security window to either uninstall this last update, run the Troubleshooter, or perform a recovery.
So I am now at the point of having to do a complete fresh Windows 10 install; unless someone has answer.
Any thoughts or fixes, please??
David
Highlighted
Community Manager
I agree that it could be actually an issue related to the operating system.
I would suggest to reinstall the operating, but before download Windows® 10 again just in case, since the copy that you have might be corrupted.
To create a Windows® 10 installation media, please follow the instructions in the next link: https://www.microsoft.com/en-us/software-download/windows10
Xavier A.
Highlighted
Community Manager
I was checking your case and would like to know if you need further assistance. If so, please do not hesitate in replying back.
Xavier A.
Highlighted
"unsupported signal. Check your device output."
I believe recent Windows10 update potentially caused this problem, either KB4043961 or the one before it.
Specs;
NUC7i3BNH.
4GB RAM.
Sony Bravia TV.
HDMI connected.
I've done nothing else to this system recently other than windows10 updates. So no changes to BIOS at all & this has happened.
Highlighted
Yes, you are right xTropodx, it most definitely is Windows 10.
Apparently, version 1703 build 15063.674 was the latest build that was safe for my system using Optane Memory. Without the Optane Memory I was able to upgrade later builds of Windows 10 satisfactorily.
Microsoft engineers are supposed to be looking into this problem according to the Microsoft Customer Support person who had to get engineers involved to look at this problem.
I have had to turn off the Windows update facility and wait for the next major update. I'm definitely going to backup everything (or even make a disk image) before I do any my updates.
Thanks to everyone that assisted, and it helps anyone suffering the same problems.
DacorDave
Highlighted
Community Manager
I do apologize that we were unable to find a solution for the issue other than wait for a fix from Microsoft®.
Still, I am submitting a feedback to let my superiors know about this problem and that it is apparently related to the Windows® Fall Creators Update (version 1709) with the hope they can find a workaround as soon as possible.
Xavier A.
Highlighted
Community Manager
I have good news for you. A few days ago, a new driver was released and it provided fixes for issues related to compatibility with Windows® 10 Fall Creators.
You can try updating the driver before upgrading the operating system to get better support. I would recommend you to first uninstall and delete the current driver, and the do a manual installation of the driver.
Please follow the steps below to uninstall the graphics driver:
  1. On the keyboard, press WinLogo key + R, then type in devmgmt.msc
  2. Expand the Display Adapters section.
  3. Find the Intel® Graphics Driver. The driver can also be called the Intel® Graphics Media Accelerator Driver (Intel® GMA Driver).
  4. Right-click the Intel Graphics Driver and select Uninstall.
  5. Select the check box Delete the driver software for this device.
  6. Reboot the computer after the uninstall process has finished.
Please follow these steps in order to update the graphics driver:
  1. Download the graphics driver ZIP file: https://downloadmirror.intel.com/27266/a08/win64_15600.4849.zip
  2. Unzip the file to a designated location or folder.
  3. Right-click Windows Start icon and open Device Manager.
  4. Click Yes when prompted for permission from User Account Control.
  5. Expand the Display adapters section.
  6. Right-click the Intel® graphics entry and select Update Driver Software.
  7. Click "Browse my computer for driver software".
  8. Click "Let me pick from a list of device drivers on my computer".
  9. Click "Have Disk".
  10. Click "Browse".
  11. Access the designated location or folder, and access a folder called "Graphics".
  12. Select the file called "igdlh64" or "igdlh".
  13. Click Open, then click OK, and finally click Next. Drivers are now being installed.
  14. Reboot your computer.
Please let me know if this fixes the issue.
Xavier A.
Highlighted
Hi there,
I had pretty much the same issue: downloaded the Windows 10 Fall Creator Update on my HP Notebook and then could no longer connect to my Sony TV (not a Bravia though) where it game the unsupported signal message. The notebook is a 64-bit with a Intel 620 graphics driver.
I followed your instructions above and it worked like a charm. Thank you so much!
Highlighted
I had this EXACT same issue with a new NUC7i7BNH. Tried to access the drivers per your post to fix it (your link is broken). My system is Windows 10 Pro and none of the video drivers would update or install (says installer not supported for this processor). After a week of frustrating experiences with Windows 10 I was finally able to figure out a way to resolve the problem. The Creators UPDATE breaks the system (non bootable). So I went to the Microsoft site for the Windows Media Creation tool: https://www.microsoft.com/en-us/software-download/windows10?tduid=(026aa3008bbfa5206e46d77cac8e398c)...(92X363X219a24d9b7dbd63d1b2bbb219bc0a59d https://www.microsoft.com/en-us/software-download/windows10?tduid=(026aa3008bbfa5206e46d77cac8e398c)... and ran it to make a NEW bootable USB drive. It downloads the LATEST version of Windows 10 installer that CONTAINS the Creators update (so now it is part of the base installation and NOT an update!). I was able to run this new installer and the system is now fully functional with no more driver issues.
Highlighted
This issue is still present (at windows 10, version 1709, os build 16299.192) and the official solution works perfectly.
I had to replace my HDD and did a clean install of the earliest windows 10 version. Before updating to version 1709 i was able to connect my Dell laptop and the Sony Bravia TV. But once i updated to version 1709 i got the error.
Highlighted
Community Manager
Hello bhuvan,
Thank you for contacting Intel Support,
I understand you are experiencing similar problems and I do apologize for the inconvenience. However, this thread has been marked as resolved.
Please submit a new thread since we handle every case individually and every scenario is different even if the same product is being used. The next agent will be able to further assist you on this matter.
David V
