Intel® NUCs
12323 Discussions
Update Assistant Tray says 2 updates available, when I check for new drivers it says 1 Update available. The update is for the ITE IR receiver and fails to install. WTF is going on? Screenshots below, the NUC is a Hades Canyon.
TomTiddler
LeonWaksman
Download the latest Driver form the Intel Download Center and install it manually.
Leon
TomTiddler
Nope. Same error, same error code.
n_scott_pearson
Super User Retired Employee
Try uninstalling the old driver. Do so from ​Apps & Features, not Device Manager. Reboot and then install the latest version.
TomTiddler
Nope again. Same problem, same error code. Incidentally. there is no such driver shown in Apps & Features, nor are there any devices resembling a CIR driver in Device Manager, also, no devices reproting problems in Device Manager.
LeonWaksman
I've reinstalled the latest driver without problems. In the Apps & features it is listed under name ITE Infrared Transceiver. Check in Bios Advanced > Devices > Onboard Devices that Enhanced Consumer IR is enabled. If you will enable it, you will find in Device Manager, under Human Interface Devices this driver named: ITECIR Infrared Receiver (EC) . So, if you can't install this driver, uninstall the currently installed version and install the latest.
Leon
