Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Update BIOS
In bios there is an option to update bios. When doing it I get a massage no Internet connection. But it is connected. Should I updated it manually? Or should I always updated bios to the latest?
Highlighted
Hello Kladde,
We have escalated that behavior to the Engineering team since it is not working.
At this moment you can update the BIOS using the following methods. http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm Desktop Boards — BIOS Update Instructions
Thanks a lot for the feedback.
Silvia L
Highlighted
Kladde, please let me know which is the current BIOS version?
Highlighted
My BIOS version is 0032.
Highlighted
New Contributor III
Same with 0033 on D54250WYK.
At first I thought the error was because no DHCP server is present on the same network as NUC but now when I have such the error is still there.
Another error is if you disable "Update over Internet" in VisualBIOS settings and save the setting isnt stored. When entering BIOS after reboot the "Update over Internet" is still enabled... (while other settings do stick when you save them).
