Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
12003 Discussions
Upgrade Intel Wireless-AC 8265 to AX201 on NUC8i7HVK
chuachongchee
I am currently using the Intel® NUC Kit NUC8i7HVK. Can i upgrade my wireless from the Intel Wireless-AC 8265 + Bluetooth 4.2 to the Intel® Wi-Fi 6 AX201?
LeonWaksman
1.I would rather choose AX 200 then AX 201. The AX 200 has standard connector interface M.2 : PCIe, USB (same as in AC 8265), while AX 201 has M.2: CNVio2 interface.
2. Please read this thread: https://www.reddit.com/r/intelnuc/comments/chxbr5/wifi_6_on_hades_canyon_for_less_than_20/
Leon
chuachongchee
So the AX200 should work ok?
There were some replies online at the amazon page saying this requires 10th gen cpu.. any truth to that? any idea?
LeonWaksman
  1. AX200 should work. I don't have this adapter, however, you may read the report from other user (see para.2 in my post above), confirming this.
  2. I don't see any requirement for 10th generation CPU in the data sheet https://gzhls.at/blob/ldb/1/b/f/6/bcfcd25c37dd3e565c26d773a4ecc5476665.pdf
  3. CNVio2 interface, used in AX201 adapter, requires the Intel 400 series chipset and 10th gen processor to work.
Leon
chuachongchee
AlHill
None. I installed an AX200 on a 6th gen and it works as it should.
Doc
chuachongchee
