I recently did a CPU comparison between my NUC's i5-5250U and the NUC5i7RYH's i7-5557U.
There appears to be a significant betterment and I was idly wondering whether it is possible to convert my NUC5i5RYH into an NUC5i7RYH.
Does anybody know whether this is feasible?
The SOCs appear to be pin compatible, so technically this would seem possible. There are three problems:
1. While these processors share a BIOS, the branding is going to be different between a NUC5i5RYH and a NUC5i7RYH. I am unsure, but this could create some issues.
2. The SOC is a PGA device, wave soldered to the board. Removing and replacing the device is fraught with issues.
3. The heatsink/blower unit on the i5 processor is designed to dissipate the heat of that processor. That on the i7 must be able to dissipate the additional heat. This may require a different heatsink/blower unit. It is unclear whether manual changes in blower management (via the fan speed control configuration in the BIOS) will be sufficient to overcome this.
Of these three, # 2 is the most problematic. In my experience, even when turning the task over to a very experienced technician with access to the best equipment, there is still a significant fallout rate. I thus cannot recommend the attempt.
Hope this helps,
Hope this helps,
Thank you indeed for your detailed answer. It really does sound like a dead duck.
I continue, therefore, to await the release of the 9th generation NUC.
