Community
cancel
Showing results for
Search instead for
Did you mean:
BSaun
Usb-c driver issue?
Have my HNK all set up and running, the DSA utility is reporting that there is an update for the usb-c power avsilable- it appears to be the same version and date as the one I installed. After letting DSA download and reinstall, it still seems to think there is an update available. Anyone else seeing this?
I don't have any usb-c devices to test to see if it is working, but my other USB devices all seem to be working normally.
Community Manager
Hello mrbillz
Thank you for joining the community.
Have you tried to scan the system with another browser do you have the same situation?
Could you try the scan the system in 24 hours please let know if you have the same output?
Leonardo C.
Community Manager
Hello mrbillz
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
