Community
cancel
Showing results for
Search instead for
Did you mean:
cvall1
Using m.2 to pcie on a NUC Board NUC7i7DNBE
In my use case i would need to have 4 more ethernet ports and a camera link interface on this board, would it be possible to use the m.2 interfaces to have pcie expansion cards?
Community Manager
Hello PhysicsNstuff,
Thank you for contacting us.
I understand that you need to increase the ports capabilities of your Intel® NUC Board NUC7i7DNBE
In this case I regret to inform you that on the Intel® NUC Board NUC7i7DNBE, the M.2 interfaces are reserved only for SATA drives, the best recommendation that we could provide in this case scenario is to take advantage of the USB ports of the unit through an adapter (USB to Ethernet, or USB to LAN for the camera).
I hope this helps.
Diego S.
Community Manager
We just wanted to double check if you still need further assistance.
Please do not hesitate on contacting us back.
Diego S.
